Billy1981
Feb 04, 2018Aspirant
XR500 Compatible with Xfinity Comcast
Will this work with Xfinity (comcast) I really wanna pick this up
- Feb 05, 2018
Try Motorolas MB74xx series or Arris 6183 or 8200. These are Broadcom based modems.
I have the MB7420 and connected to my XR500. Wonderful operations.
Please avoid the SB6190 and any other Intel based modems.
You can check on what to avoid here:
Netduma-Fraser
Feb 04, 2018NetDuma Partner
Hi Billy, yes it will definitely work with your connection setup!
- Billy1981Feb 04, 2018AspirantWhat would be a good combination (modem), with the xr500 as im looking to by my own to avoid rental fees
- Netduma-FraserFeb 05, 2018NetDuma PartnerThere is none specifically that I would recommend but I'd say to avoid those with the Puma 6 chipset as they have issues with latency (not sure if that's been resolved on all of them yet).
- FURRYe38Feb 05, 2018Guru - Experienced User
