Pallywood's avatar
Mar 23, 2020
Xr500 connected to EX7700 via ethernet
Hello. I connected the extender to the router via ethernet, to help with the backhaul. My android TV box and Laptops then we're not able to get DHCP IP addresses. Even after forgetting the WiFi conne...
  • plemans's avatar
    Mar 23, 2020
    yeah the tribands need to be in AP mode for hardwired backhaul.
    I'd try the speedtest with it in AP mode and in extener mode with the wireless backhaul. You might be surprised at how well the wireless backhaul works (provided you have a decent router)
