Mrw00z's avatar
Mrw00z
Tutor
Sep 29, 2020
XR500 connection after reset
Does anyone else have an issue where the router will not reconnect to the modem after reset? Specifically if the modem is reset first, then the router, it will not connect until the modem is reset ag...
