RMSands
Jan 10, 2023Guide
XR500 Connection Benchmark Issue
DumaOS Version 2.3.2.130. Connection Benchmark works and displays when scheduled. When clicking "Run Test", circle spins for about 8 seconds. Nothing displayed in any of the three graphs and nothing ...
- Jan 12, 2023
I wouldn't suggest connecting to the interface using HTTPS as you may encounter errors and issues. The interface is local so it's secure.
Go to the QoS page, click the menu on the Congestion Control panel and change your speeds there.
We use https://speed.measurementlab.net/#/ for the speedtest and it seems quite a lot of people don't get full speeds to it. If you get expected speeds through speedtest.net then the router won't be limiting you
Jan 10, 2023Guru - Experienced User
What browser are you using?
Happens with other browsers as well?
Be sure to clear out all browser caches before entering the routers web page and try again.
Has a factory reset and setup from scratch change any behaviors?
Had this been working before?
You behind one FW version FYI.
- RMSandsJan 10, 2023Guide
Firefox 108.0.2 (latest version)
Edge and Chrome cannot connect when using HTTPS. They both connect and work when using HTTP.
In trying the other browsers, I discovered that Firefox works when connecting via HTTP but fails when connecting via HTTPS.
