RMSands
Jan 10, 2023Guide
XR500 Connection Benchmark Issue
DumaOS Version 2.3.2.130. Connection Benchmark works and displays when scheduled. When clicking "Run Test", circle spins for about 8 seconds. Nothing displayed in any of the three graphs and nothing ...
- Jan 12, 2023
I wouldn't suggest connecting to the interface using HTTPS as you may encounter errors and issues. The interface is local so it's secure.
Go to the QoS page, click the menu on the Congestion Control panel and change your speeds there.
We use https://speed.measurementlab.net/#/ for the speedtest and it seems quite a lot of people don't get full speeds to it. If you get expected speeds through speedtest.net then the router won't be limiting you
Netduma-Fraser
Jan 10, 2023NetDuma Partner
What is the model of the modem the XR is connected to? Do you have the XR in the DMZ of your ISP modem or have the modem set to bridge mode?
- RMSandsJan 11, 2023Guide
ISP is fiber optic to Calix 725GX ONT on the outside of the house then Cat 6 direct to XR500.
