RMSands's avatar
RMSands
Guide
Jan 10, 2023
XR500 Connection Benchmark Issue
DumaOS Version 2.3.2.130. Connection Benchmark works and displays when scheduled. When clicking "Run Test", circle spins for about 8 seconds. Nothing displayed in any of the three graphs and nothing ...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Jan 12, 2023
    I wouldn't suggest connecting to the interface using HTTPS as you may encounter errors and issues. The interface is local so it's secure.
    Go to the QoS page, click the menu on the Congestion Control panel and change your speeds there.
    We use https://speed.measurementlab.net/#/ for the speedtest and it seems quite a lot of people don't get full speeds to it. If you get expected speeds through speedtest.net then the router won't be limiting you
