shiden
Apr 29, 2021Aspirant
XR500 Connection drops constantly due DHCP renewal
This is really painful, I think is since I upgraded firmware recently from Netgear. At random times, but most noticiable when I try to play a game like Overwatch. I lose connection to server and I am...
shiden
Apr 30, 2021Aspirant
Yes, I did factory reset, every time I tested the firmwares. Which is really painful as I have to readd all the devices back to the router.
I will try with an older firmware and see what happens but this problem seems to have been around for a while and not going anywhere.
Thanks
Netduma-Fraser
Apr 30, 2021NetDuma Partner
Do other devices experience disconnects or is it just this one device? If you disable the Geo-Filter does it happen less?
- shidenApr 30, 2021Aspirant
There are other devices doing the same pattern ranging from computers to android tv, Alexa, etc. But not all the devices do this behavior only a few connected on different things, Wireless, and cable. Geofilter is not added for any device so it should be off.
- Netduma-FraserApr 30, 2021NetDuma PartnerIn LAN Settings change the DHCP pool to start at 192.168.1.50 instead, then set reserved IPs for your affected devices between .2 & .49 and then reboot the router and see if it still occurs.
- shidenMay 01, 2021Aspirant
This is really frustrating as I said. I went I set the dhcp pool to start at 30, then I assigned Ip's like 10 to the affected devices and I still get intermitent DHCP lease events, how is this even possible :(. I tried similar solutions to this before but I always got the same results.
Look at this big spam of lease
changes for a reserved address :(
[DumaOS] DHCP lease change., Saturday, May 01, 2021 09:43:09 [DumaOS] DHCP new event., Saturday, May 01, 2021 09:43:09 [DHCP IP: 192.168.1.19] to MAC address , Saturday, May 01, 2021 09:43:09 [DumaOS] DHCP lease change., Saturday, May 01, 2021 09:43:01 [DumaOS] DHCP new event., Saturday, May 01, 2021 09:43:01 [DHCP IP: 192.168.1.19] to MAC address , Saturday, May 01, 2021 09:43:01 [DumaOS] DHCP lease change., Saturday, May 01, 2021 09:42:52 [DumaOS] DHCP new event., Saturday, May 01, 2021 09:42:52 [DHCP IP: 192.168.1.19] to MAC address , Saturday, May 01, 2021 09:42:52 [DumaOS] DHCP lease change., Saturday, May 01, 2021 09:42:26 [DumaOS] DHCP new event., Saturday, May 01, 2021 09:42:25 [DHCP IP: 192.168.1.19] to MAC address , Saturday, May 01, 2021 09:42:25 [DumaOS] DHCP lease change., Saturday, May 01, 2021 09:42:21 [DumaOS] DHCP new event., Saturday, May 01, 2021 09:42:21 [DHCP IP: 192.168.1.19] to MAC address , Saturday, May 01, 2021 09:42:21 [DumaOS] DHCP lease change., Saturday, May 01, 2021 09:42:12 [DumaOS] DHCP new event., Saturday, May 01, 2021 09:42:12 [DHCP IP: 192.168.1.19] to MAC address , Saturday, May 01, 2021 09:42:12 [DoS Attack: ACK Scan] from source: 52.84.169.64, port 443, Saturday, May 01, 2021 09:42:08 [DumaOS] DHCP lease change., Saturday, May 01, 2021 09:42:06 [DumaOS] DHCP new event., Saturday, May 01, 2021 09:42:06 [DHCP IP: 192.168.1.19] to MAC address , Saturday, May 01, 2021 09:42:06 [DumaOS] DHCP lease change., Saturday, May 01, 2021 09:42:01 [DumaOS] DHCP new event., Saturday, May 01, 2021 09:42:01 [DHCP IP: 192.168.1.19] to MAC address , Saturday, May 01, 2021 09:42:01 [DumaOS] DHCP lease change., Saturday, May 01, 2021 09:41:38 [DumaOS] DHCP new event., Saturday, May 01, 2021 09:41:38 [DHCP IP: 192.168.1.19] to MAC address , Saturday, May 01, 2021 09:41:38 [DumaOS] DHCP lease change., Saturday, May 01, 2021 09:41:18 [DumaOS] DHCP new event., Saturday, May 01, 2021 09:41:18 [DHCP IP: 192.168.1.19] to MAC address , Saturday, May 01, 2021 09:41:18
