nytiger73
Oct 28, 2018Star
XR500 Connection Issues
Hello -
I bought an XR500 to replace my R8000 last week. I was tired of some of the issues I was having with the R8000. I had tried a Linksys, but that didn't seem to work out too well. Any...
Netduma-Fraser
Oct 31, 2018NetDuma Partner
That wouldnt fix the hardwired devices, I've sent you a PM hollar.
nytiger73
Nov 01, 2018Star
I now seem to be having an issue with my hardwired PC as well out of nowhere. It just drops IP addresses out of nowhere. Initially, I changed ports on the router and it fixed it temporarily, but a short time later it lost the IP address again. It has been fine for days. What can I try to fix this? I've tried resetting my networking within Windows to no avail.
Thank you.
- Netduma-FraserNov 01, 2018NetDuma PartnerI've sent you a PM tiger
- nytiger73Nov 04, 2018Star
That firmare was a steaming pile of crap. I loaded it onto my router and no device on my entire network could get an IP or connect to the Internet. I rebooted my modem and router multiple times to no avail. I even went so far as to do a factory reset on the router which finally got the router to see my connection, but I still couldn't get Internet access on any device, despite multiple reboots, resets forgetting networks etc
Just so I could get back online, I hooked up my old R8000 which went flawless. The XR500 is going back to Best Buy tomorrow. I am not sure if I will try another one or not. I went a router that is going to work out of the box and support all of my devices without me having to jump through constant hoops to keep them working. I understand that I may need to reboot things here and there, but I'm honestly terrified to reboot this thing. I don't know how long I'm going to be down for.
Any other ideas?
