SallieBeast
Jun 23, 2020Aspirant
XR500 Connection Issues
I have the XR500 Gaming Router and after 5 months it has stopped functioning properly. I am outside the 90 day window to have it replaced. I have been prompted to purchase a 50.00 plan to see what ma...
Raf1212
Jun 23, 2020Apprentice
I also have problems with xr500, you have to wait for 3.0 software, how the software sucks, I'm going to ASUS
ROG Rapture GT-AX11000
- Netduma-FraserJun 23, 2020NetDuma PartnerIn Internet Setup switch to static. In LAN Settings give devices reserved IPs. For WiFi disable Smart Connect if enabled and use a WiFi analyzer to find the least congested channels and then change to that for both 2.4/5GHz. Do you see any improvements then?
