StarFirezz
May 22, 2019Tutor
Xr500 Connection through WAN port causes issues
When I connect through the WAN port my gigabit internet goes down to 90mbs but when connected as a switch it pushes out the gigabit internet I should be getting what is wrong with my router?
- May 24, 2019
Recieved replacement XR500 from Amazon, plugged it in, got through the initial setup, and first speed test was over 750Mbps. So as it seems it was a faulty router. Thank you all for your help!
May 23, 2019Guru - Experienced User
Speed testing wired or wireless? Wired is perferred first.
Has a full power OFF of both ISP modem and XR router for 30 seconds, then back on with the ISP modem first then the XR router been performed?
Netduma-Fraser
May 23, 2019NetDuma Partner
Let us know if it happens again with the new router and we'll be able to troubleshoot with you, it is likely a misconfiguration issue.
- StarFirezzMay 24, 2019Tutor
- FURRYe38May 24, 2019Guru - Experienced User
Glad the new router worked. Please mark your thread as solved so others will know.
Enjoy.
