tacticalrandy
Jul 31, 2019Aspirant
Xr500 connectivity issues with LAN
Good Evening, I just recently purchased the Nighhawk Pro Gaming XR500 and I am currently having the same issue everyone else is having with the LAN connection not working. Currently all my devices t...
Netduma_Alex
Aug 01, 2019NetDuma Partner
Have you tried the hotfix firmware? https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
- tacticalrandyAug 01, 2019AspirantTried the update still having same issue. Turned on Xbox and it has no internet connection everything else is working fine.
- FURRYe38Aug 01, 2019Guru - Experienced User
Ensure your xbox networking settnings are set to Automatic. Remove any static IP addresses if present.
Swap LAN cables.
Do you see any Front LED on the front of the XR router for the xbox console when it is turned on? Which port you use should light up whent the xbox is turned on. WHITE should be seen.
To clear any networking caches from the console, hold the front power button until the console turns off. Let then go. Then power back on.
- tacticalrandyAug 01, 2019AspirantMy xbox says it cannot locate IP address. On the router the lights are blinking white for the Xbox, it used to be orange when it was off even though my Xbox is off now its still blinking white.
