Jayrjose
Jul 17, 2020Follower
XR500 Constant Internet Drop
Hi I have recently bought the XR500 and lately it’s been dropping the internet. All of the lights are on and operation and it tells me I have internet but anything that is connected to it ( both hard ...
lucianls
Jul 18, 2020Tutor
It's a old problem ... you are not the only one ... but they don't bother to fix it. Downgrade your firmware to v 2.3.2.40 and check if you have the same problems.
Netduma-Fraser
Jul 19, 2020NetDuma Partner
Fixes will be coming in the beta, so do sign up if you haven't already. It's also worth mentioning that a user on our forum has encountered a potential fix so give that a try also: https://forum.netduma.com/topic/31686-xr500-internet-dropping-out/?do=findComment&comment=255005
