cebasss
Jan 17, 2022Follower
xr500 constantly loses connection needs manual reboot
hello every morning i need to reboot my router manual unplug the switch then back on i don't need to wait 30 sec since it works like normal every time and i also do the modem from my isp and this has...
Netduma-Fraser
Jan 19, 2022NetDuma Partner
Set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
