BraveHeart95
May 28, 2019Aspirant
Xr500 Constantly rebooting !
hello i bought Nighthawk XR500 about 9 months ago from newegg the router itself is great , amazing wi-fi range ,qos , geo filter and all other features are great but it is been constantly rebooti...
Netduma-Fraser
May 28, 2019NetDuma Partner
Sorry to hear you're having this issue, do you have the router plugged into a power extender by any chance? If so plug it directly into the wall and see if that resolves the issue.
BraveHeart95
May 29, 2019Aspirant
no i am plugging it directly
- Netduma-FraserMay 29, 2019NetDuma PartnerHas anything changed in your setup or house (e.g. wiring) when the issue started?
- BraveHeart95May 29, 2019Aspirant
no i didn't change anything
the ISP gave me a bad router i used for the first month that was working perfectly fine without any interruptions but with the XR500 it started rebooting from the first day i bought although the internet itself is working
- Netduma-FraserMay 29, 2019NetDuma PartnerSo it's been rebooting itself for 9 months? I'd suggest you make a ticket with Netgear here: http://support.netgear.com/ sounds like it could be faulty.
