jonnysbazar
May 01, 2020Aspirant
Xr500 Constantly rebooting !
Guys Just came here from the topc I read one costumer had the same problem that I am having! I opened a ticket and someone here fixed the rebooting problem for Xr500? Every 15 min it stops and start...
Netduma-Fraser
May 01, 2020NetDuma Partner
First I would suggest plugging directly into a wall outlet to rule out any issues with a power extender. If it still occurs try using a different power adapter with the same voltage to see if that is faulty. If it still occurs then I would recommend you get the router replaced.
