LightManeye
Nov 01, 2021Aspirant
XR500, crash every 24 hour
Hi, from 2 months my XR500 V2.3.2.120, crash every day. I have tried with a simply reset and a factory reset with a new config, but the problem returns promptly in 24 hours. Im trying to disa...
Nov 01, 2021Guru - Experienced User
What modem/gateway is it connected to?
- lxbradorNov 01, 2021AspirantIt’s connected to a Virgin Media Superhub 4. Wasnt an issue until like 2-3 weeks ago
Just stops responding, drops wifi first then locks up- Netduma-LiamNov 01, 2021NetDuma Partner
lxbrador Did any changes to the environment or network occurs prior to this issue randomly occuring? Did you factory reset your XR500 after upgrading to the latest beta firmware? Are you getting any error messages in the interface prior to the disconnection occuring?
LightManeye Are you seeing any error messages in the interface prior to the disconnection occuring? After changing the DHCP range, did you then reserve IPs for your devices within the .2 to .50 range? That's the important bit.
- LightManeyeNov 02, 2021Aspirant
I have changed DHCP, but the problem comes back on time..
I can't see any error in log, because the modem reboot after 2/3 minutes after the cresh...
- FURRYe38Nov 02, 2021Guru - Experienced User
Is the XR router connected to this ISP router or dirrectly to the ISP ONT?
If you have the Virgin Media Superhub 4 this already has wifi and router built in. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
Just stops responding, drops wifi first then locks up- LightManeyeNov 02, 2021Aspirant
FURRYe38 wrote:Is the XR router connected to this ISP router or dirrectly to the ISP ONT?
Couple of options,
Just stops responding, drops wifi first then locks upThe XR is connected to ISP ONT, we don't have any other wifi or HUB connected.
FIBER => ONT (huawei) => XR500
- LightManeyeNov 01, 2021Aspirant
Im connecte to HUAWEI ONT and the connection is Vodafone fiber (italy).
