LightManeye
Nov 01, 2021Aspirant
XR500, crash every 24 hour
Hi, from 2 months my XR500 V2.3.2.120, crash every day. I have tried with a simply reset and a factory reset with a new config, but the problem returns promptly in 24 hours. Im trying to disa...
lxbrador
It’s connected to a Virgin Media Superhub 4. Wasnt an issue until like 2-3 weeks ago
Just stops responding, drops wifi first then locks up
Netduma-Liam
Nov 01, 2021NetDuma Partner
lxbrador Did any changes to the environment or network occurs prior to this issue randomly occuring? Did you factory reset your XR500 after upgrading to the latest beta firmware? Are you getting any error messages in the interface prior to the disconnection occuring?
LightManeye Are you seeing any error messages in the interface prior to the disconnection occuring? After changing the DHCP range, did you then reserve IPs for your devices within the .2 to .50 range? That's the important bit.
