walle1
Jul 29, 2020Aspirant
XR500 Custom Hybrid AWS VPN not working
I can connect to my vpn with the .ovpn files generated from the AWS debian 10 buster linux server with or without password(made 2 .ovpn accounts, one with pass, one without) on both a pc and mac. ...
Netduma-Fraser
Jul 29, 2020NetDuma Partner
Thank you, while I look over this do you know which OpenVPN version this will be using?
walle1
Jul 30, 2020Aspirant
OpenVPN 2.4.7 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Feb 20 2019
library versions: OpenSSL 1.1.1d 10 Sep 2019, LZO 2.10
Originally developed by James Yonan
Copyright (C) 2002-2018 OpenVPN Inc <sales@openvpn.net>
Compile time defines: enable_async_push=no enable_comp_stub=no enable_crypto=yes enable_crypto_ofb_cfb=yes enable_debug=yes enable_def_auth=yes enable_dependency_tracking=no enable_dlopen=unknown enable_dlopen_self=unknown enable_dlopen_self_static=unknown enable_fast_install=needless enable_fragment=yes enable_iproute2=yes enable_libtool_lock=yes enable_lz4=yes enable_lzo=yes enable_maintainer_mode=no enable_management=yes enable_multihome=yes enable_pam_dlopen=no enable_pedantic=no enable_pf=yes enable_pkcs11=yes enable_plugin_auth_pam=yes enable_plugin_down_root=yes enable_plugins=yes enable_port_share=yes enable_selinux=no enable_server=yes enable_shared=yes enable_shared_with_static_runtimes=no enable_silent_rules=no enable_small=no enable_static=yes enable_strict=no enable_strict_options=no enable_systemd=yes enable_werror=no enable_win32_dll=yes enable_x509_alt_username=yes with_aix_soname=aix with_crypto_library=openssl with_gnu_ld=yes with_mem_check=no with_sysroot=no
- Netduma-FraserJul 30, 2020NetDuma PartnerThank you, I think the issue is that it's trying to authenticate with the user/pass as part of the config but we don't support that. Can they provide a new config where you can input the user/pass outside the config?
- walle1Aug 02, 2020Aspirant
This is the error in Custom VPN Hybrid with no user/pass .ovpn:
Wed Jul 29 16:13:06 2020 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jul 16 2019
Wed Jul 29 16:13:06 2020 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06
Wed Jul 29 16:13:06 2020 ERROR: username from Auth authfile '/tmp/lua_J1lnA6' is empty
Wed Jul 29 16:13:06 2020 Exiting due to fatal error- walle1Aug 02, 2020Aspirant
Forum would not paste text so here's 2 images of the .ovpn with no user/pass:
