racersimage
Feb 17, 2018Guide
XR500 Custom VPN?
How can I use my TorGuard VPN configuration on this router? I only see an option for HideMyAss.
Netduma-Fraser
Feb 18, 2018NetDuma Partner
At the moment you cannot. However, we are introducing a new VPN solution in the next firmware. That should then allow you to use alternative VPN providers.
- racersimageFeb 18, 2018Guide
Well that's good news I guess. I have already setup a return through Amazon for the router because of the VPN Client limitation but if a custom option is coming, I guess I can hold off on the return. I was disappointed to see only one Client but figured that HideMyAss must have paid to be the exclusive VPN Client for this router.
- Netduma-FraserFeb 18, 2018NetDuma PartnerI totally understand and will be much more powerful than the standard VPN client that is currently used. You'll be able to select the individual devices that are VPN'd rather than applying to all devices. If you're interested it will be very similar to this: https://netduma.com/features/vpn-hybrid/
It will be available in March.- racersimageFeb 18, 2018Guide
That's even better!
I came from an Asus RT-AC86U with Merlin FW that allowed me to specify which devices utilized the VPN which was awesome.
I didn't think this router had the capability to do that but that was going to be ok as long as I could continue using my VPN Client that I've already subscribed to but when I couldn't see an option, I was pretty dissapointed.
Now to find out that the next firmware will support this, and the ability to specify which devices to use the VPN Client on, without requiring the use of a 3rd Party Firmware is excellent news!
- EmmaParkerJun 11, 2018Aspirant
I have PureVPN, so can I configure my VPN on this router? And the malware 'VPNFilter' attacked many routers so if I confiure a VPN on it, so does it add a security layer? or would you like to recommend me something else?
- Netduma-FraserJun 11, 2018NetDuma PartnerNo just yet but when VPN Hybrid is available then yes. I don't believe the XR500 was on the list of affected routers but here is some advice provided by Netgear on the matter: https://community.netgear.com/t5/General-WiFi-Routers/Security-Advisory-for-VPNFilter-Malware-on-Some-Routers/td-p/1576170
- lmcgekoApr 10, 2019Aspirant
Its April - when can i configure my EarthVPN on the router?
Key reason i bought the router is I could configure the VPN at the router level.If it is not going to be possible, I would like to return the router.
- schumakuApr 10, 2019Guru - Experienced User
Assuming also this VPN provider does allow to generate an OpenVPN config file - go to the Advanced settings on the Hybrid VPN - there you past the complete OpenVPN config file, including the (in-line) certificate http://support.netduma.com/support/solutions/articles/16000087492--dumaos-optimal-settings-guide-hybrid-vpn this is available since Hybrid VPN is available, not just since April 1st.
- XolhidJun 18, 2018Apprentice
Fraser, I do appreciate all the hard work you guys have done, but would you guys please refrain from telling customers "next firmware". You guys have a long history and bad reputation of giving false feature release firmware/dates. I have lost count how many features you guys said would be in the "next firmware" that didn't happen. Thank you.
Maybe just use "future release". It encompases a larger time frame without putting you in a corner.
- Netduma-FraserJun 19, 2018NetDuma PartnerThanks for the feedback, I have stopped saying that now :)
