racersimage
Feb 17, 2018Guide
XR500 Custom VPN?
How can I use my TorGuard VPN configuration on this router? I only see an option for HideMyAss.
racersimage
Apr 07, 2018Guide
You could go with a two router solution as others have mentioned or just return it and buy a router with OpenVPN that doesn’t require you to use their own paid VPN service. That’s what I did.
1234kdy
Apr 07, 2018Aspirant
Yea I returned it going to get a different router and going to research a router that fits my needs instead of an impulse buy. Im looking at the routers recommend by my vpn provider. Like flashed routers with the vpn provider.
- Netduma-FraserApr 08, 2018NetDuma PartnerSorry to hear your disappointment. Netduma's VPN solution will be coming and should allow more free choice of VPNs that can be used.
