racersimage
Feb 17, 2018Guide
XR500 Custom VPN?
How can I use my TorGuard VPN configuration on this router? I only see an option for HideMyAss.
jordy787
Apr 29, 2019Guide
Why is it that if I use ipvanish through my router my download speed is 20mbps but if I use the windows client then its about 200+mbps?
- Netduma-FraserApr 30, 2019NetDuma PartnerThere is a limitation when using the router, that is why the VPN Hybrid is available so you can apply it to only certain applications/services and then every other device/every other application/service on the device can run through the normal connection.
