racersimage
Feb 17, 2018Guide
XR500 Custom VPN?
How can I use my TorGuard VPN configuration on this router? I only see an option for HideMyAss.
nickbayleys
Aug 16, 2018Aspirant
Not all VPNs allows you to use unlimited devices. I've used Express VPN with 3 devices, but a month ago I bought Raspberry Pi 3 Model B+ for Kodi and I had to switch to Surfshark just to be able to connect the 4th device. Which VPN provider do you use to browse online?
chaoticbeliever
Jan 22, 2020Aspirant
Yes not all VPN providers offer muti device login. I use Ivacy VPN for browsing online and yes configuring a VPN to your router does add an extra security layer. With a VPN set up directly on your router, yours and cyber criminal's devices will automatically be encrypted, meaning that you’ll still have a certain level of safety and anonymity. This also means that no matter what the attacker may be trying to do on your network, which may be illegal in some cases, it will be impossible to trace the activity back to you.
