Sidz_Gaming_
Jan 26, 2022Guide
XR500 DAILY INTERNET DROPS
XR500 FW 2.3.2.130 Hello all this is my 1st post to please bare with me i bought my xr500 (XRM570) and i have been having issues ever since i set it up, internet drops i thought it was my ISP so...
Netduma-Fraser
Jan 26, 2022NetDuma Partner
Set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
- Sidz_Gaming_Jan 26, 2022Guide
most of my devices i have put in the Address Reservation but will try this, when the internet goes completely down i can not even acsess the routers page
ps. my computer is hard wired
thank you
- Netduma-FraserJan 26, 2022NetDuma PartnerIt is a known issue unfortunately but hopefully by doing that step it will reduce the frequency
- Sidz_Gaming_Jan 26, 2022GuideOkay, being a known issue how come net gear didn’t say that, also is there likely to be a fix, I read that it has been an issue in past few updates
- steiNettiMar 08, 2022Tutor
Netduma-Fraser are those IP ranges specific? I really don't want to reconfigure the whole house (reserved addresses are between 50 and 119) to eventually get a workaround..
I'd rather set the DHCP range to > 120 if that's an option and leave reserved adresses as-is..
- Netduma-FraserMar 08, 2022NetDuma PartnersteiNetti No it's not specific, as long as you have reserved IP address outside of the DHCP range then that is the main thing to help prevent the issue.
- steiNettiMar 10, 2022Tutor...nope. it just dropped. Again.
