Sidz_Gaming_
Jan 26, 2022Guide
XR500 DAILY INTERNET DROPS
XR500 FW 2.3.2.130 Hello all this is my 1st post to please bare with me i bought my xr500 (XRM570) and i have been having issues ever since i set it up, internet drops i thought it was my ISP so...
Netduma-Fraser
Jan 26, 2022NetDuma Partner
Set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 2 minutes and see if that stops the disconnects.
steiNetti
Mar 08, 2022Tutor
Netduma-Fraser are those IP ranges specific? I really don't want to reconfigure the whole house (reserved addresses are between 50 and 119) to eventually get a workaround..
I'd rather set the DHCP range to > 120 if that's an option and leave reserved adresses as-is..
- Netduma-FraserMar 08, 2022NetDuma PartnersteiNetti No it's not specific, as long as you have reserved IP address outside of the DHCP range then that is the main thing to help prevent the issue.
- steiNettiMar 10, 2022Tutor...nope. it just dropped. Again.
- Netduma-FraserMar 10, 2022NetDuma PartnerWhat is the model of the modem/router the XR connects to? Do you know if you have a dynamic public IP?
