vhelixr
Mar 24, 2022Aspirant
XR500 dead due to reboot
hi my xr 500 router stopped working after rebooting from routerlogin.net web page, Tried all troubleshooting steps still same error, Solid red light below power symbol, After pressing reset the red ...
Mar 24, 2022Guru - Experienced User
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
