vhelixr
Mar 24, 2022Aspirant
XR500 dead due to reboot
hi my xr 500 router stopped working after rebooting from routerlogin.net web page, Tried all troubleshooting steps still same error, Solid red light below power symbol, After pressing reset the red ...
Apr 02, 2022Guru - Experienced User
If you've tried everything and can't recover the router, the router is probably bad and needs replaceing. You'll need to contact NG support and see what your options are: https://my.netgear.com/support/contact.aspx
