DRU732
Oct 25, 2018Tutor
XR500 Device Manager is unusable.
It is really difficult to find, identify and manage the devices on my network with this router.
The standard tables normally used by Netgear are significantly more useful than this unreadable map o...
Dec 18, 2018Guru - Experienced User
Well Device Manager seems to be better in v.40...This is taken from a 15" Mac Book Pro.
- Netduma_JackDec 19, 2018NetDuma Partner
Good to hear! You can also toggle it into a table if you prefer (click the options button in the top left corner of the Network Map panel).
- FURRYe38Dec 20, 2018Guru - Experienced User
Oh I didn't know that. I will try this out.
Thank you. :smileywink:
