ErwinZ
Feb 24, 2019Tutor
XR500 Device Manager issues
Gents,
I'm experiencing odd things with the Device Manager view of the XR500:
1. Sometimes when I try to select a device, from either the Device table or the Device tree I get the error :...
Netduma-Fraser
Feb 24, 2019NetDuma Partner
1. As above, what web browser are you using? Do you see this issue in Google Chrome?
2/3. I'm wondering if the browser isn't updating the information on the view that's not shown properly, do you observe the same behaviour on Chrome? Is the device in a standby/rest mode? If so packets every so often will be transmitted, keeping the connection alive so you can't delete it.
