ErwinZ
Feb 24, 2019Tutor
XR500 Device Manager issues
Gents,
I'm experiencing odd things with the Device Manager view of the XR500:
1. Sometimes when I try to select a device, from either the Device table or the Device tree I get the error :...
Netduma-Fraser
Aug 07, 2019NetDuma Partner
I don't think you'd be able to have it in modem mode if it wasn't passing through VLAN. You would probably have to keep it in router mode. Yes the settings will be overridden by going back to modem mode. Perhaps best to use router mode on dm200 for VLAN and PPPoE then put the XR500 in its DMZ.
Diabhalta
Aug 07, 2019Star
Well it definitely works as had it that way last few months. However just moved to new house with a switch, heatmiser and sonos and having a nightmare setting up!
Excuse my ignorance but why is running dm200 as router and xr500 in dmz better? Any pro's and con's versus modem (with vlan id set) or modem (with vlan passthrough) ? Have tried both and they work but dont seem to play nice with others!
- Netduma-FraserAug 07, 2019NetDuma PartnerIt may be better in that the XR500 doesn't deal with VLAN at all as it can cause issues with QoS at the moment. Has the guest WiFi worked?
- DiabhaltaAug 07, 2019StarActually looking at manual and settings, I dont see any DMZ option in the DM200.
No luck with guest wifi but I'm thinking I potentially fail at Sonos in all environments!!! - DiabhaltaAug 07, 2019StarAlso, reading a thread here with someome with exact same issues and it was fault with dm200. He even had same thing as I am seeing where during setup the speed test measures download correctly but upload is 1000mbs (should be 15mbs)
- Netduma-FraserAug 07, 2019NetDuma PartnerIn that case would you be able to try a different modem and see if the issue is still present?
Thanks Fraser, I think I'm giving up! I plugged in my Draytek and boom, everything works with zero setup. So confused and will miss the QoS and gaming features!
- Netduma-FraserAug 07, 2019NetDuma PartnerCan you not use the draytek with the XR500 at all?
- DiabhaltaAug 07, 2019StarYeah I will try that in the next few days when I have regained my troubleshooting energy! Will let you know how it goes, thanks so much for the help!
- Netduma-FraserAug 08, 2019NetDuma PartnerGreat let us know, you should be able to use the two together if the Draytek can replace the DM200.
- DiabhaltaAug 08, 2019StarThanks Fraser, I will report back for sure. Might be a few days as my ISP asked me to leave the connection alone for a few days so they can sign off on an unrelated fault.
Been racking my brain on what the issue might be, do you know if that issue with MTU size on dm200 in bridge mode got fixed? Where 1492 wasnt working and some users had to go as low as 1400 to stop packet loss?
The challenge with the draytech 2862 is I cant figure out how to get bridge mode for PPPoE connection, manual and googling tells me only option is PPPoE passthrough which I dont want, I would want full bridge mode. I dont understand the mechanics of why the draytech has bridge mode option for all other protocols? - Netduma-FraserAug 08, 2019NetDuma PartnerI haven't heard of that so can't say unfortunately. Do you have the option of modem or DMZ mode to use? Looking at the modem it has a lot of features so they maybe just thought it wasn't needed.
- DiabhaltaAug 09, 2019Star
There were a few people reporting MTU problems with the DM200 in bridge mode. Issue seemed to be despite 1492 being selected it was having issues until manually setting to as low as 1400. I had similiar symptoms where some websites and apps wouldn't work despite having perfect speedtests etc.
One commonality I've seen between my issues and others with similiar issues is when the speedtest is done on the XR500 during setup it returns correct download speed but 1000mbs upload speed. Not sure what this implicates but seems a common canary in the gold mine.
Either way, I'm up and running now and leaving stable for a few days at my IPS's request. Then I'll try to get a different modem or router in bridged mode to test if it's the DM200, XR500 or both having a problem.
- Netduma-FraserAug 10, 2019NetDuma PartnerThanks for the info. Sometimes the speed test can report incorrectly during setup so it's best to always double check after setup and change the speeds manually if necessary. Glad to hear that, keep us posted!
