EurynomeStolas
Mar 02, 2019Guide
XR500 Device manager shows multiply wired devices
so here is my device manager. I have the XR500 in the basement wifi disabled. the R8000 in the family room in AP mode. Then i have the X4 upstairs. I am curious why the device manageer shows the ...
- Mar 05, 2019Device Type only makes a difference when it has been classed as a console. It affects the way that the Geo-Filter & Traffic Prioritization treats it.
Mar 03, 2019Guru - Experienced User
If your R8000 is in AP mode and WIRED to the XR router, then anything connecting to the R8000 gets detected as WIRED since the R8000 is WIRED to the XR router.
- Netduma_JackMar 05, 2019NetDuma Partner
The Device Manager sees it as wired because the R8000 is wired into it. There's no real way around this, but maybe we could allow users to configure this?
As for the misnamed devices, the default type is Computer if we don't recognise it. We try to auto-recognise every connected device, but we don't catch them all. So simplest thing to do is click on the device and change the type and give it a name of your choosing.
- EurynomeStolasMar 05, 2019GuideI was wondering if some things are better then others. Like I have a Nividia sheild for example. What would you put that as in the devicemanager? Does putting it as let’s say a tv make it less faster then a tablet? I am just curious what would be the best. It’s just used for streaming. You understand what I am asking.
- FURRYe38Mar 05, 2019Guru - Experienced User
Put it as a Streaming device.
