EurynomeStolas
Mar 02, 2019Guide
XR500 Device manager shows multiply wired devices
so here is my device manager. I have the XR500 in the basement wifi disabled. the R8000 in the family room in AP mode. Then i have the X4 upstairs. I am curious why the device manageer shows the ...
- Mar 05, 2019Device Type only makes a difference when it has been classed as a console. It affects the way that the Geo-Filter & Traffic Prioritization treats it.
Mar 05, 2019Guru - Experienced User
Put it as a Streaming device.
EurynomeStolas wrote:
I was wondering if some things are better then others. Like I have a Nividia sheild for example. What would you put that as in the devicemanager? Does putting it as let’s say a tv make it less faster then a tablet? I am just curious what would be the best. It’s just used for streaming. You understand what I am asking.
Netduma-Fraser
Mar 05, 2019NetDuma Partner
