Dropbottom
Dec 03, 2021Tutor
XR500 DEVICE NOT FOUND
XR500 130 firmware QOS No Device Found. I have tried everything mentioned on this website. Please provide an official go-by fix to address this issue.
Netduma-Fraser
Dec 04, 2021NetDuma Partner
Downgrade to the .114 firmware, do a factory reset, then upgrade to .130 and don't do a factory reset, it should work after that.
- Mike40Dec 05, 2021Luminary
Do you have a link for the .114 firmware?
I upgraded my internet so I factory reset (it never will use the new speed if I don't) but then I got the device not found error. My PS5 lagged worse than before I bought the XR500 a year ago (8/20) since I can't use the QOS. When I did the factory reset it updated the firmware to .130 and I got the error so I went back to .120 and reset everything again and still the same error. You would think for a $300 product you wouldn't have issues like this but now I'm stuck with it. I'm really wishing I took it back after the first one didn't work and just got my money back.
Also after factory resetting everything twice, my QOS settings never changed. The congestion slider and the allocation have stayed the same but devices, Geo-Filter, etc all reset.
I use Chrome to access DumaOS and I have cleared everything and still same error.
Since I'm stuck with this router now, can you please assist?
Thanks :)- Netduma-LiamDec 06, 2021NetDuma Partner
The link for the 114 firmware: https://kb.netgear.com/000062867/XR500-Firmware-Version-2-3-2-114
Once you've downgraded and upgraded again, let us know if you're still having issues and we'd be happy to assist further.
- Mike40Dec 06, 2021Luminary
That worked to get rid of the pop-up error. When I get off work, I will put all my devices back on and let you know if I have anymore issues.
Thanks for your help.
