Brennan73
May 10, 2020Aspirant
XR500 DFS Network Channels
Good Afternoon, I ran a WiFi Analyzer and it recommends that I change my 5.0GHz wireless network to a DFS channel. I know very little about these types of channels but understand there are certain ru...
May 11, 2020Guru - Experienced User
Some older wifi devices may not work with DFS channels are used.
36-48 and 149-165 are best to use.
- Netduma-FraserMay 12, 2020NetDuma PartnerThere is a risk that you could be disconnected from the channel if radar is detected on that channel while it switches to another. If this happens when you're gaming then you could be kicked from the game.
