kaitech
Aug 19, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
Netduma_Jack
Aug 20, 2018NetDuma Partner
Hi - I would recommend giving the XR500 a static WAN IP on the modem if it has the option to and see if that fixes your problem.
kaitech
Aug 20, 2018Aspirant
Why would the WAN interface DHCP setting affect LAN interfaces? This sounds like it's a software issue with DumaOS if that's the case.
- Netduma-FraserAug 21, 2018NetDuma PartnerI've PM'd you, please see if that firmware fixes the issue.
