kaitech
Aug 19, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
Jan 15, 2019Guru - Experienced User
Try a manual FW load. You might revert back to intial shipping FW to see if the problem is seen there. Factory reset after manually loading FW and setup from scratch.
Set the Default DHCP IP address pool from 192.168.1.1/.254 to 192.168.1.100 to .200.
Try this. Ensure that your using reserved IP addresses for chosen devices ON the router. Ensure that when using Static IP address ON devices that these IP addresses are outside of the default DHCP IP address pool set on the router.
- Netduma-FraserJan 15, 2019NetDuma PartnerAs above, have you tried the most recent firmware? Also are the devices in instant on/standby modes?
- Rick6922Jan 16, 2019Luminary
ive done all that. its a fw issue
usless you no something about the new FW that the netgear tec people dont, please let me no and Netgears tec people no too. according to NG its a FW issue. they couldnt get the new FW running right hooking everything up there selfs through team veiwer.they said not to use new FW. it drops the internet four 2 to 5 secs.not good for online gamming , skyping or anything live.
sorry, I meant to be on xr700 topic!
