kaitech
Aug 20, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
Katgomeow
Jan 15, 2019Aspirant
Im having the same issue, set static ips and still keeps happening, is there anyway to get acess to the beta firmware to see if that solves the issue?
Jan 16, 2019Guru - Experienced User
Let us know if this suggestion helps:
Try a manual FW load. You might revert back to intial shipping FW to see if the problem is seen there. Factory reset after manually loading FW and setup from scratch.
Set the Default DHCP IP address pool from 192.168.1.1/.254 to 192.168.1.100 to .200.
Try this. Ensure that your using reserved IP addresses for chosen devices ON the router. Ensure that when using Static IP address ON devices that these IP addresses are outside of the default DHCP IP address pool set on the router.
