kaitech
Aug 20, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
Netduma-Fraser
Jan 24, 2019NetDuma Partner
Cobra, have you used previous firmware that users confirmed they don't see the issue on?
COBRA00000
Jan 27, 2019Aspirant
Not sure which firmware I had as I exchange the router. I do know I had the most up to date firmware. If there is a beta firmware I did ask how I could get it once before. Anyways I tried 3 routers this weekend I just went with Nighthawk x10 everything seems fine just having issue with one game black ops yes I did port triggering etc. Before I get told go to the nighthawk pag, Thanks for your help couldn’t keep resetting router everyday and not being able to connect to my house when I wasn’t home. Guess time will tell with the nighthawk x10 hope it works I’m at a big lost between the 2 routers now lol
- Netduma-FraserJan 27, 2019NetDuma PartnerSo you don't have the XR500 anymore? If so sorry to hear that and I hope you'll consider it again in future.
- COBRA00000Jan 27, 2019AspirantNo I returned the XR500 under protection plan to Best Buy. I bought the Netgear Nighthawk X10. Just can’t play one game right now. All ports open and NAT is open.
- Netduma-FraserJan 27, 2019NetDuma PartnerSorry to hear that, hope you consider it again in future
