kaitech
Aug 19, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
cFonzy
Feb 07, 2019Aspirant
I'm having the same issue. I just purchased the XR700 and thinking of returning it. Many of my devices will not connect to WiFi. Some say failed to obtain IP address. I've tried everything I can think of with no solution. Could I please try this BETA firmware? Netduma-Fraser
My log is attached file.
Feb 07, 2019Guru - Experienced User
Try reverting back ot v20 FW. Other 700 users reported having resolved problems with this prior version of FW.
Also do a factory reset after downgrading and setup from scratch.
Also set the DHCP IP address pool to 192.168.1.100 to .200.
