kaitech
Aug 19, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
Slaine80
Mar 06, 2019Tutor
I have the same problem as you, I am in version XR500 V2.3.2.40 and my journal is filled with message DHCP !!!
Possible to have a beta version?
there is another solution?
Mar 06, 2019Guru - Experienced User
Set the Default DHCP IP address pool from 192.168.1.1/.254 to 192.168.1.100 to .200.
Try this. Ensure that your using reserved IP addresses for chosen devices ON the router. Ensure that when using Static IP address ON devices that these IP addresses are outside of the default DHCP IP address pool set on the router.
- Netduma-FraserMar 06, 2019NetDuma Partnerslaine are you having any issues from this or just increased log entries?
- Slaine80Mar 06, 2019Tutor
Netduma-Fraser My log filled with DHCP notification and all my devices are disconnected in chain and for several minutes
- FURRYe38Mar 07, 2019Guru - Experienced User
What happens with the suggestion I mentioned?
