kaitech
Aug 19, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
LOCKxPerses
Mar 10, 2019Aspirant
The wired connection stops after I turn xbox off or disconnect the ethernet cable from the xbox. And it will not reconnect to the internet even though it shows it works. It also kicks me off randomly when I'm playing when its wired.
- Netduma-FraserMar 10, 2019NetDuma PartnerI'm not sure I understand, other devices are affected by you turning off/unplugging Xbox? What game are you playing? If you disable the Geo-Filter does that prevent the random kicks?
- LOCKxPersesMar 10, 2019AspirantYes I have done all those things I play battlefield, anthem and some other like games the only thing that Is affected is my wired in xbox. The ip address on it is very weird. I'm not sure if that is the issue.
- Netduma-FraserMar 10, 2019NetDuma PartnerWhat's the IP address that you're getting? So you do not see buffering/lag on any other devices when it occurs? If you connect directly to the modem does it still happen?
