kaitech
Aug 19, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
Slippin_Jimmy
Feb 25, 2020Aspirant
I'm having the same issue, when the PS4 is downloading in rest mode, the downloads pause at the same time there is a DHCP lease change. I've already ordered a new router from Asus as I have got zero help with this issue on the Netduma forums and on here(although I only posted here 12 hours ago).
On firmware V2.3.2.56.
What's the deal? Is it dodgy fw if so what should I have been using and where do I find it.
Not going in depth on all my troubleshooting as I have done so in my own post here and on duma forums, but rest assured I have narrowed it down to this router as the culprit.
Netduma-Fraser
Feb 25, 2020NetDuma Partner
I've responded in both your topics on here and the Netduma forum.
- Slippin_JimmyFeb 25, 2020Aspirant
Replying doesn't equate to helping. You have offered zero help in fixing the issue. Thanks for absolutely nothing but complete, and utter incompetence. You and the so called Netgear support, which is also distinctly lacking.
- Netduma-FraserFeb 25, 2020NetDuma PartnerI posted in the topics a few hours ago asking you a question that could be a workaround based on a previous issue that it has similarities to.
- Oasis81Mar 08, 2020Tutor
Anyone have fix of this problem? i have the same problem with my pc's
hard reset didn't works.
sometimes pc lost his ip and the only way is to reboot the router.
i've last firmware and i have this router since 20 months, and it works well until now.
is there a fix or i send it back?
