kaitech
Aug 19, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
Oasis81
Mar 08, 2020Tutor
Anyone have fix of this problem? i have the same problem with my pc's
hard reset didn't works.
sometimes pc lost his ip and the only way is to reboot the router.
i've last firmware and i have this router since 20 months, and it works well until now.
is there a fix or i send it back?
GooniesNvrSayDi
Mar 08, 2020Apprentice
2.3.2.22 is the only firmware that works for me. So much for staying relevant with security and functionality. Best solution is to return it if possible and buy an Asus. Hopefully they’ll treat us better.
- Oasis81Mar 08, 2020Tutor
thanks for the info.
have you any suggest about the asus? maybe one that can manage VPN better than this?
- Netduma-FraserMar 08, 2020NetDuma PartnerOasis81 is it only your PC disconnecting from the internet? Are all other devices fine? If so I would look at first updating the network drivers on the PC.
hi
no not only mine
also other equipment, and i have 15 equipment, are connect to wifi and don't take the ip. not all at the same time... but atm just 4 of them.
2 pc, 1 ipad and 1 phone.
and also, my router usually is not reachable correclty., same as picture attached.
is too slow to load the manu and give that error sometimes
