kaitech
Aug 19, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
Netduma-Fraser
May 26, 2020NetDuma Partner
You can now sign up for the beta so I'd suggest doing that so you're more likely to get in it sooner http://www.netgearinnovation.com/dumaos-beta/index.html
GooniesNvrSayDi
May 27, 2020Apprentice
Signed up
- GooniesNvrSayDiJun 12, 2020Apprentice
I was accepted into the beta program but I get an Access Denied when I try to access the Beta Forum link.
- Netduma-FraserJun 12, 2020NetDuma PartnerChristineT can you help?
- NicoB7700Jul 27, 2020Aspirant
I'm having this same issue. Started after a few months of owning the router. I'm a streamer too, so having my router suddenly having these constant drops in the middle of a stream is incredibly annoying. I tried signing up for the beta, but I haven't heard back about it. Are they accepting anymore people?
- Netduma-FraserJul 28, 2020NetDuma PartnerSorry to hear you're having this issue. Yes they will be sending more invites. The fix isn't in the beta build currently available but will be in a later one. People have found that downgrading to .32 or .40 seems to resolve the issue so perhaps try that. Please note you will miss out on some security fixes if you do that.
- DelxSep 28, 2020Apprentice
Hi all, I am having the same issue coudlnt get ip address for android devices after a few days and have to rester my router. When this happens also cannot access the router settings very well get "The operation is taking longer than expected. Please briefly wait before using this R-App."
Just bought this 2 weeks ago!!
- Netduma-FraserSep 28, 2020NetDuma PartnerPlease try the open beta and see if that helps with your issues https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
- DelxOct 25, 2020ApprenticeHi I tried this but now after 3 weeks the issue is back but worse. The router now crashes several times a day. Before I could still access the net via Ethernet but now it disconnects completely?
- Netduma-FraserOct 26, 2020NetDuma PartnerI've thought of something new that might help. NG show a lot of false positives for attacks in the log, they may actually be blocking packets that are required and therefore cause disconnects. Could you try disabling the DoS protection in WAN Settings please?
- BPowellOct 26, 2020TutorI ended up trashing the XR500 and buying an Asus RT-AX88U. Much more stable and has 8 LAN ports which is great because I'm thinking about setting up a NAS and can use link aggregation.
The stock firmware is better too. - DelxOct 26, 2020Apprentice
I will try that but not a very happy disabling Port Scan and DoS Protection!
- Netduma-FraserOct 26, 2020NetDuma PartnerThe router still has a firewall so you should be protected regardless. If that is the issue I can let NG know.
- DelxOct 27, 2020Apprentice
Well that has not worked either, now the wifi crashes while ethernet works fine and I cannot login to the router all i get it is This Rapp is not loaded yet, please try again in a minute. I have to hard reset.
Have Pm'd youy my log after hard reset.
- Netduma-FraserOct 27, 2020NetDuma PartnerUnfortunately I don't have any more recommendations at the moment as it is a legitimate bug but I am talking to the NG team lead right now and he's discussing with the developer about it. Will get back to you as soon as I have any new information.
Probably the best bet is to try the beta or downgrade to a firmware that may be more stable for you. - DelxNov 02, 2020Apprentice
Any more updates on this, I am getting fed up of restarting the router several times a day and may just end up giving it back.
- GooniesNvrSayDiNov 02, 2020Apprentice
The beta resolved this issue for me. Where you able to get the beta installed? And, did you do a factory reset after you installed the beta?
Yup it workewd for about 2 weeks then same issues
- Netduma-FraserNov 03, 2020NetDuma PartnerI'm talking with the NG lead at the moment regarding this, previously I was relying on others to pass the details on so hopefully I can work with him to try and get this sorted asap.
- DelxNov 03, 2020Apprentice
Just factory reset the router and still same problem
- Netduma-FraserNov 03, 2020NetDuma PartnerThe only thing I can suggest really is to use TFTP to upgrade then reset as that will give you the freshest install possible and hopefully mitigate any issues.
- DelxNov 14, 2020Apprentice
any further updates? it def is a RAM problem i think
- Netduma-FraserNov 14, 2020NetDuma PartnerNo updates at the moment, still trying to converse with NG on it.
- tekonsiteDec 05, 2020ApprenticeI am having the same issue now every day and it is frustrating. When will Netgear resolve this issue?
- Netduma-FraserDec 05, 2020NetDuma PartnerI'm still working on that, have you tried any of the suggestions so far?
- tekonsiteDec 05, 2020ApprenticeI am going to try the new beta firmware. Has that been known to fix these dhcp issues or has that not been implemented yet? I am currently on the latest firmware .66. You mentioned that some customers have had success with .40 and .32 firmware. What do you recommend?
- Netduma-FraserDec 05, 2020NetDuma PartnerThe latest beta build we released just this last week I haven't seen many if any reports of disconnects so I'd start there first.
