kaitech
Aug 19, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
GooniesNvrSayDi
Nov 02, 2020Apprentice
The beta resolved this issue for me. Where you able to get the beta installed? And, did you do a factory reset after you installed the beta?
Delx
Yup it workewd for about 2 weeks then same issues
- Netduma-FraserNov 03, 2020NetDuma PartnerI'm talking with the NG lead at the moment regarding this, previously I was relying on others to pass the details on so hopefully I can work with him to try and get this sorted asap.
- DelxNov 03, 2020Apprentice
Just factory reset the router and still same problem
- Netduma-FraserNov 03, 2020NetDuma PartnerThe only thing I can suggest really is to use TFTP to upgrade then reset as that will give you the freshest install possible and hopefully mitigate any issues.
- DelxNov 14, 2020Apprentice
any further updates? it def is a RAM problem i think
- Netduma-FraserNov 14, 2020NetDuma PartnerNo updates at the moment, still trying to converse with NG on it.
- tekonsiteDec 05, 2020ApprenticeI am having the same issue now every day and it is frustrating. When will Netgear resolve this issue?
- Netduma-FraserDec 05, 2020NetDuma PartnerI'm still working on that, have you tried any of the suggestions so far?
- tekonsiteDec 05, 2020ApprenticeI am going to try the new beta firmware. Has that been known to fix these dhcp issues or has that not been implemented yet? I am currently on the latest firmware .66. You mentioned that some customers have had success with .40 and .32 firmware. What do you recommend?
- Netduma-FraserDec 05, 2020NetDuma PartnerThe latest beta build we released just this last week I haven't seen many if any reports of disconnects so I'd start there first.
- tekonsiteDec 05, 2020ApprenticeI'm trying the latest beta right now. So far so good as it was a clean install. I also did a factory reset right after confirming install was successfull. I will keep you up to date.
- tekonsiteDec 06, 2020ApprenticeLooks like the same issue, as the internet was again out this morning at 6am. As soon as I power cycle the XR500 the internet is back up. Very frustrating and disappointed with this product and that it is a very expensive router. I expect the most basic functionality of DHCP to work correctly. There looks to be an issue when the lease expires. Please keep pushing developers to fix this. I have read some of the forums and this issue has been going on for over a year. Customers are going to get fed up with this and purchase products from other brands. Reliability is extremely important for your brand at Netgear. If word gets out to youtube influences and the media it will not be good for Netgear...
- DelxDec 06, 2020Apprentice
It really is ridiculous for a top of the line router.
I have found that disabling 5ghz wifi seems to improve the ram usage on the router with less crashes.
- Netduma-FraserDec 06, 2020NetDuma PartnerThanks for the information and sorry to hear it is still occurring. I've linked the entire topic to the XR500 lead so hopefully we'll make some headway. Set static/reserved IPs where you can for devices and the router itself as this may help.
- BPowellDec 06, 2020Tutor
Netduma-Fraser If you recall from further up in this thread I started, this doesn't work. Static/Reserved IPS are still subject to issues when the DHCP lease time expires. This happens even if you set the IPs to outside the DHCP range.
I gave up on Netgear and this router after waiting for nearly a year for a firmware update. The router is currently at the garbage dump. The XR500 was the first Netgear router I've purchased, but it will be my last until it can be proven that Netgear is more mindful of basic functionality. The Asus RT-AX88U blows this router out of the water both hardware and firmware wise.
- tekonsiteDec 06, 2020ApprenticeThanks for your support Netduma-Fraser. I know you are trying to help and I see you have the difficult job of responding to every question on this forum related to XR500. It is in Netgears best interest to get a fix for this as soon as possible. I will be reaching out to youtube influencers that have showcased this model and see what they say. Setting ip reservations for all my devices on my home network is not a feasible solution. I will try a few things you suggested with the gateway static ip and have a look at my ISP modem / router (bridged). The main issue I have observered is the XR500 router drops dhcp connection to the Arris ISP modem. The Arris ISP modem has a set dhcp lease of 11h 59min. I am not sure why the XR500 will not reconnect once the lease expires. Perhaps this info will help the developers. Once the XR500 reboots it establishes a new connection with the Arris ISP modem.
- Netduma-FraserDec 06, 2020NetDuma PartnerBPowell the one most likely to help is to set a static IP for the router itself as I believe part of the problem is when the ISP modem/router renews its lease that the XR has trouble re-establishing the connection.
tekonsite thanks for the understanding. That's partly my theory as well If you take that out of bridge mode and set the IP and use it in the DMZ then it may resolve the issue - tekonsiteDec 08, 2020ApprenticeUpdate: So far the XR500 has not lost DHCP settings from Arris ISP Modem. This is is what I did...
1. Power cycled the Arris Modem
2. Power cycled XR500
3. Logged into both to check, all good
4. When logged into Arris Modem in bridge mode I noticed the 4 ports have energy efficiency turned on. I turned that off on the port the XR500 is plugged into.
5. DHCP has been stable so far for two days now.
I will further update at the end of the week. - Netduma-FraserDec 08, 2020NetDuma Partnertekonsite thanks for posting what works for you, fingers crossed it continues that way.
- tekonsiteDec 14, 2020Apprentice
Just wanted to confirm the new .108 beta resolves the dhcp issues for my XR500.
- TimChangDec 16, 2020NETGEAR Employee
Hi,
Sorry been late to feedback the DHCP issue you have now.
Please kindly install this debug firmware - https://ntgr-my.sharepoint.com/:u:/g/personal/tichang_netgear_com/Ecek7S3fUjZHmGi11s60rNQB1eZUv5HHh-oxeMpiEHaclA?e=nAdeNI
And follow the steps to get the debug logs for our analysis if you still can see the issue.
- Plugin a USB device to DUT. Open debug page: http://192.168.1.1/debug.htm
- Select the checkbox “Enable WAN/LAN Packet Capture”.
- Choose “USB Device” in store location.
- Click "Start Capture" button.
- Once issue occurs, press the Button “Save debug log”.
- Send the log to us.
Please make sure in the capture file in \\192.168.1.1\USB_Storage\Capture, there are lan.pcap and wan.pcap file inside.
I can see some users disable the power saving in the ISP modem, this is a good approach to idenify the issue. The Ethernet switch chipset may have some issue to handle the power saving mode.
- tekonsiteDec 18, 2020Apprentice
I have had the router now crash two times this week. Today it was very strange, I turned on my Galaxy Note 20 and the internet looked to be fine and then all of a sudden the XR500 crashed. No internet, so I rebooted the XR500 and the internet was back op again. I am hoping the crashes are less frequent but this is really getting rediculous. I will wait again for a new update to the beta firmware as it looks like there will be no further updates after .66.
- Netduma-FraserDec 18, 2020NetDuma PartnerIf you could upgrade to the firmware above and do the capture then that will help the NG to narrow down the issue and provide a fix.
- tekonsiteDec 24, 2020Apprentice
Sorry, I have been very busy and have not had a chance to perform the firmware flash. I am still having issues as it does disconnect every couple of days. I will do this after the holidays.
- Netduma-FraserDec 25, 2020NetDuma Partnertekonsite no worries, let us know how it goes once you've managed to upgrade. Happy holidays!
- tekonsiteDec 26, 2020ApprenticeYesterday the connection dropped three times in one day. A reboot fixes the connection due to dhcp disconnect from my ISP modem. I will try to load the firmware you gave me in this thread on Monday.
