kaitech
Aug 19, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
tekonsite
Dec 29, 2020Apprentice
I have been doing some research on this issue and Netgear is having this DHCP issue on other model routers. What is going on and why is this not more of a priority?
Netduma-Fraser
Dec 30, 2020NetDuma Partner
I can't speak for there other routers but I've been pushing them heavily for the XR routers, if they get enough information maybe that will help them fix all the affected routers.
- tekonsiteJan 01, 2021ApprenticeJust wanted to add that I turned off QOS and I haven't had a disconnect since and it has been over a week. Possible issue is related to QOS with DHCP.
- TimChangJan 03, 2021NETGEAR Employee
tekonsite What do you mean the "turn off QoS"? Do you check the "Disable QoS" from Congestion control menu?
Netduma-Fraser If disabling QoS can solve the issue, still need your team's effort to look into any iptables issue to possible block the DHCP packets.
- tekonsiteJan 03, 2021ApprenticeI can say that this is definitely related to QOS. Since I have selected "Never" under Congestion Control from "Auto Enable" I am yet to have a DHCP disconnect. I was very surprised to say that it has been stable for almost 10 days without a reboot.
tekonsite Thanks for this information. This is the Netduma feature, i need Fraser to comment on it.
Netduma-Fraser Would you help to take a look of this case of the DHCP issue?
- Netduma-FraserJan 04, 2021NetDuma PartnerI have not seen it be specifically related to QoS in the past but I'll get people to test it.
- DelxJan 04, 2021Apprentice
I will this now see if it helps.
My disconnects are back since I enabled smart connect? I was only using 2.4gz wifi and it had been fine for weeks. only thing changed is have enabled smart connect and set up the ex7700 extender that came with the router?
- Netduma-FraserJan 04, 2021NetDuma PartnerDid you get any disconnects from wired devices? Please do try that, would be interested to know the results.
No only have 1 wired pc and thats been fine
- tekonsiteJan 04, 2021Apprentice@Delix, since you have been only using 2.4Ghz in the recent past and switched to smart connect, check to see if your wireless devices can connect to 5Ghz. Also check if they are compatible with IEEE 802.11k, 802.11r and 802.11v standards that let clients roam more seamlessly from access point (AP) to AP within the same network. That is what Smart Connect is along with a single ssid for all AP radios. The XR500 has two radios and the EX7700 has 3 radios. Hope that helps as I have the XR500 and 3 EX7700 Access points.
- DelxJan 07, 2021Apprentice
Def an issue with smart connect, dont get a full day without some devices coming up authentication error.
Have now turned smart connect off and 5ghz wifi. only using 2.4ghz!!
- Netduma-FraserJan 07, 2021NetDuma PartnerI'm not sure if it's specifically related to Smart Connect - that's probably some devices not switching properly between 2.4/5GHz when using one SSID. There is an issue with DHCP lease I believe and NG are looking at it right now.
Def Smart connect the devices that have issues are mostly phones and we have the lastest phones Samsung S20+ so dont see why they dont work
- Netduma-FraserJan 07, 2021NetDuma PartnerDelx do you notice it when using the beta at all?
- DelxJan 07, 2021ApprenticeYes I am using the latest beta
- Netduma-FraserJan 07, 2021NetDuma PartnerOkay could you follow the information here please and provide the requested info to Tim when it happens? https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-108-XR500/m-p/2035205/highlight/true#M3180
- DelxJan 08, 2021Apprentice
still problems with ip!
- Netduma-FraserJan 09, 2021NetDuma PartnerDelx please provide the entire debug log including LAN/WAN capture and Private Message TimChang when you have it
- DelxJan 09, 2021Apprentice
how do I upload on pm?
- Netduma-FraserJan 09, 2021NetDuma PartnerDelx click attach at the bottom of the text box, or upload to dropbox for example and provide the link.
