kaitech
Aug 19, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
tekonsite
Jan 01, 2021Apprentice
Just wanted to add that I turned off QOS and I haven't had a disconnect since and it has been over a week. Possible issue is related to QOS with DHCP.
TimChang
Jan 03, 2021NETGEAR Employee
tekonsite What do you mean the "turn off QoS"? Do you check the "Disable QoS" from Congestion control menu?
Netduma-Fraser If disabling QoS can solve the issue, still need your team's effort to look into any iptables issue to possible block the DHCP packets.
