kaitech
Aug 20, 2018Aspirant
XR500 DHCP issue
I've had this router for 4 months now and it works fine most of the time. Once in a while I'll notice that some LAN devices become unresponsive, when I look into the issue it turns out that they have...
Delx
Jan 04, 2021Apprentice
I will this now see if it helps.
My disconnects are back since I enabled smart connect? I was only using 2.4gz wifi and it had been fine for weeks. only thing changed is have enabled smart connect and set up the ex7700 extender that came with the router?
Netduma-Fraser
Jan 04, 2021NetDuma Partner
Did you get any disconnects from wired devices? Please do try that, would be interested to know the results.
- DelxJan 04, 2021Apprentice
No only have 1 wired pc and thats been fine
