Anonymous
Feb 25, 2019XR500 DHCP lease change
Hi,
I’ve been having disconnection issues with my new XR500 router on my Xbox. At least once a day I get disconnected from Xbox Live for a split second and then reconnects again. According to t...
- May 22, 2019
If you go to Settings > Monitoring > Connection Status, it should tell you when your internet connection lease renews. Maybe that will renew at just the wrong time? Try renewing it manually from this screen to move the expiry time to something more convinient.
Feb 25, 2019Guru - Experienced User
What FW is currently loaded?
Remove the static IP address for the WAN on the XR500. Use Dynamic DHCP.
- AnonymousFeb 25, 2019
Thanks for replying.
Like I said in my opening post, my current firmware version is V2.3.2.40.
There is no modem between my router, the fiber connection comes into my house, goes through what my provider says is a “media converter” which translates the signal into something I can use. I live in the Netherlands and my provider is KPN.
What is it exactly that you mean when you speak of Dynamic DHCP? I tried to find out what that means but I can’t find anything.
Kind regards,
Wesley
- FURRYe38Feb 25, 2019Guru - Experienced User
How is the xbox connected? Wireless or wired.
After turning on the xbox. Go in and set a IP address reservation ON the router for the xbox. Try .199 for the xbox. Save setting and apply. While the router applies the change. Hold the power button ON the xbox until it turns OFF.
Reboot the router.
After the router is ready, power ON the xbox. Check networking and NAT status.
- AnonymousFeb 25, 2019When trying to implement your steps I also changed the WAN IP from static to automatic, this completely broke my connection and now the internet light on the router won’t turn on no matter what. I’m sending this thing back first thing in the morning.
