syycoe
Jul 19, 2020Aspirant
Xr500 DHCP lease change
Hello I am having problems with everything disconnecting every 15mins coinciding with lease times,everything reconnects eventually but it is impossible to game as getting kicked all the time and have ...
Netduma-Fraser
Jul 19, 2020NetDuma Partner
Is this happening on wired devices as well? In Internet Setup switch to Static there and see if that helps. Also if you go to Settings > Monitoring > Connection Status what does DHCP lease say for obtained/expires?
- syycoeJul 23, 2020AspirantDo I copy the ip from dynamic to the static details,lease obtained 15mins
- syycoeJul 23, 2020AspirantHappening hardwired and wireless it is coinciding with the lease change,occasionally you cannot connect for a minute or 2 after change
- SolarnottsJul 23, 2020Aspirant
Netgear and Duma know about this, I've had countless conversations with them via Facebook.
All they say we are aware, But it'll be fixed in the next firmware. Which is in BETA.
Could be months or knowing Duma years, I have the XR500 too and its just an expensive door stop atm feel terribly ripped off that they can actually get away with selling this when it doesn't even fuction correctly.
They give you all these work arounds when it shouldn't be that way, Your charging £250 for door stop!
