syycoe
Jul 19, 2020Aspirant
Xr500 DHCP lease change
Hello I am having problems with everything disconnecting every 15mins coinciding with lease times,everything reconnects eventually but it is impossible to game as getting kicked all the time and have ...
syycoe
Jul 23, 2020Aspirant
Do I copy the ip from dynamic to the static details,lease obtained 15mins
syycoe
Happening hardwired and wireless it is coinciding with the lease change,occasionally you cannot connect for a minute or 2 after change
- SolarnottsJul 23, 2020Aspirant
Netgear and Duma know about this, I've had countless conversations with them via Facebook.
All they say we are aware, But it'll be fixed in the next firmware. Which is in BETA.
Could be months or knowing Duma years, I have the XR500 too and its just an expensive door stop atm feel terribly ripped off that they can actually get away with selling this when it doesn't even fuction correctly.
They give you all these work arounds when it shouldn't be that way, Your charging £250 for door stop!
- Netduma-FraserJul 24, 2020NetDuma PartnerOn your ISP router give the XR router a static IP, just the same one that it has already and also put it in the DMZ. On the XR you just need to click static and it will assume the same settings, so you can then apply it.
